Posted by Cory B on May 10, 2009 at 17:08:13 from (97.91.97.149):
My H was running fine, I shut it off, and a few moments later jumped on to move it only to find it completely powerless. Nothing happens when the starter switch is depressed. I checked all connections as best I could but did not notice anything unusual. This has never happened to me in the 8 years I have had it. The battery is new last fall. It is a 6-volt positive grounded system with a regulator mounted under the gas tank. Can anyone suggest how to begin troublshooting the problem or direct me to a link where a similar situation has already been discussed?
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
