Posted by Roy Ward on May 10, 2009 at 17:43:25 from (66.82.9.74):
In Reply to: Dead H posted by Cory B on May 10, 2009 at 17:08:13:
When you say powerless do you mean no voltage or no mechanical movement of the starter. Anyway I would start with a volt meter. DC+ lead to tractor frame and start with the DC- lead from the battery and go farward thru the kill switch and on to the coil and to the points. Points need to be open and you should have 6+ all the way. Next with the DC- lead put it on the starter where the lead from the starter buttom ties to the starter. If you don't have 6+ volts there then the starter buttom or the battery + lead is loose from the frame or a bad battery connection. If it's mechanical then do what the other guy said your starter is locked up to the flywheel and you have to break it loose by rocking the tractor. The bendex may be locked in to the rain gear.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
