Posted by El Toro on May 11, 2009 at 03:55:15 from (205.188.116.73):
In Reply to: Dead H posted by Cory B on May 10, 2009 at 17:08:13:
Check the voltage on your battery using a volt meter should be at 6 volts. It may be a dead battery if your generator isn't charging it. Check your battery cells with a hydrometer and see what your readings are. Should be around 1.260 and if one cell is 1.100 you have a dead cell and you need to replace the battery. As been mentioned clean all your battery connections. You should have 00 battery cables on a 6 volt system. If you can get it started check the charging voltage across the battery terminals. Should be 7.2 volts with the engine at 1/2 throttle or better. Hal
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
