Posted by Andy Martin on May 11, 2009 at 05:27:00 from (199.197.2.142):
In Reply to: Dead H posted by Cory B on May 10, 2009 at 17:08:13:
If the engine turned while pulling then the started is not locked up. A locked starter will slid a wheel rather than release when pulled forward. To get a starter unlocked you put the tractor in fifth and rock it toward the rear. It's a little faster than unbolting the starter if the tractor has no implement and is where it can be rocked.
First step is to charge the battery and see if that fixes the problem (temporarily at least)
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
