Re: 49 C,part #
Posted by Ron-MO on May 23, 2009 at 19:32:19 from (174.131.234.198):
In Reply to: 49 C,part # posted by dougie94 on May 23, 2009 at 13:39:03:
Hope you have better luck than I did, or I had an odd ball pump. A couple years ago I had the same issue and none of the generic parts store, nor anyplace I could find had one of the correct size. Finally found one at an older IH dealer from a parts man who knew what he was talking about. All I found otherwise were either too large or too small.
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
