Re: 560 dual remotes
Posted by KY Plow Boy on May 24, 2009 at 00:22:17 from (12.30.206.21):
In Reply to: Re: 560 dual remotes posted by Rootsy on May 23, 2009 at 19:46:04:
We have a loader on it and for it to have hyd power the middle lever has to be all the way forward, which gives our right side couplers under fuel tank pressure. Those lines come out of the top right side of the valve bank, and the couplers going to the rear of the tractor come out of the same valve bank, but out of the bottom like you were saying at the top of trans. The valve bank in the center under the dash is connected to the inner lever but doesn"t have any lines or couplers coming from it.
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
