1951 FARMALL C
Posted by burnsg on May 24, 2009 at 20:54:23 from (64.12.116.73):
I have a 1951 C that I completely rebuilt. It starts and runs great but it has a zenith carb and it leaks from the bottom of the bowl. I have reset the float level and it still leaks. It gets worse when the temperature is hotter. The tractor could not start and run any better. Any ideas on how to solve this problem would be appreciated. I
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
