Re: Dreaded Antifreeze in Oil
Posted by TomA on May 25, 2009 at 08:43:56 from (64.118.116.66):
In Reply to: Re: Dreaded Antifreeze in Oil posted by Janicholson on May 25, 2009 at 08:18:57:
If the engine runs good and oil consumpsion is acceptable I would try the stopleak method before investing in a teardown. Not much to lose except some oil changes. Waterglass can be used as a permenent stopleak.
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
