Unless it is smashed or missing, and you can't find a used one to rebuild at a scrap yard, there's absolutely no reason to buy new.
If you think you're getting around the frustration of rebuilding the carb by buying new, think again. Most new carbs need to be disassembled and fixed due to rough handling during shipping. You'll have the same problem with the new carb as the old, so you may as well save yourself the hundreds of dollars and just get a $25 rebuild kit. It may take two three four or more tries to get the float right, but once you get it, you'll know how to do it for the next tractor.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
