Posted by BruceS. on June 02, 2009 at 08:24:49 from (76.15.46.128):
The liftall pump on my MD won't lift the transport disk. It's got the NAPA R and O fluid in it right now. I know it's a one way system, so I've got the return line back to the cylinder disconnected to act as a breather. Would using 30 wt. non detergent oil ( as IH originally recommended) make it work?? It does make a feeble attempt to lift the disk, but doesn't seem to build enough pressure. As always, any help appreciated.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
