Posted by John T on June 26, 2009 at 05:00:40 from (66.244.97.31):
In Reply to: F 20 no spark posted by JiminIowa on June 25, 2009 at 22:10:12:
Im NOT an IHC Mag guy butttttttttttttt the very first thing I would do if the points are like gray oxide coated is to non abrasively clean/buff/polish them shiny n see what happens. If they are burned or pitted a points file may get her going but if they are badly burned Id get a new set. Is the imuplse spring assembly winding then tripping/releasing with a good loud SNAP as you slowly crank the engine over??? If its sticking or gunked up she cant spark at cranking speed, you gotta heAr that sharp SNAP FOR THE MAG TO FIRE WHEN YOURE CRANKING IT OVER. Sometimes a good clean up and light lube can free up a sticking impulse.
If its more serious IM OUT TO LUNCH on IHC mags but this mat get you going
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
