If you are able to mow at speeds in high range. Put a hand held tach on the pto and see where the throttle sets at 540 pto rpm in high range and try not to go much higher. At no load rpm the pto turns 591 in low range. That will tell you if the governor is set right for wide open no load rpm when you get 591 at pto. Full load at 1450 engine RPM gives 537 pto rpm.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
