I had a "47 M when I was a kid.I used it for corn picking and auger wagon feeding hogs,and grinding feed with an old wetmore hammermill.It had the overdrive.I remember the first time I realized the PTO was sped up.I was going to auger feed into a building and it was in overdrive at an idle and the auger sure did sing when I let out on the clutch.I never used the PTO with the overdrive cause I figured it would tear something up
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
