Posted by Wild Bill on July 08, 2009 at 11:39:41 from (208.44.160.51):
I need the front half of the water pump pulley for a farmall H...the part that you tighten to towards the engine and tighten the belt. Mine has been cracked since I got the tractor and I cannot tighten the belt enough. I am not sure what it is called, I found this in the manual, is it what I need?
Fan and water pump pulley flange, adjustable, # 102723
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
