Posted by Dave Allgire on August 04, 2009 at 11:59:46 from (96.35.216.238):
In Reply to: F 14 fuel system posted by JLE on August 04, 2009 at 11:18:57:
If the bowl on the carb is "bone dry" that tells me the float is sticking. When the float and valve are working properly you should have about 3/4" of fuel in the bowl when you remove the top. The fitting at the top of the tank has a line from the fuel pump and one to the carb. If you were to remove the fitting you would find a small tube about 1" long and about 1/8" in diameter thats inside of the tank. The purpose of this fitting is to return any fuel that is not used by the carb back to the tank as well as provide a positive pressure to the carb. The fuel pump puts out more fuel than the carb uses hence the small tube. Since you have the carb off, I would check the inlet fuel screen. Thats the fitting on the carb that the fuel line screws into. You might also check the float for any fuel sloshing around in it. That is a no-no. With a possible leak in the float, it won't open up the needle to admit any fuel. Just some things to check.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
