Posted by glennster on August 07, 2009 at 09:25:32 from (99.131.131.158):
In Reply to: 1945 M hydraulics posted by NewRedinPA on August 07, 2009 at 08:49:37:
you can use any of the three ports. the rear port was usually used for a mounted cultivator, and a delay valve was put in the line so the rear cultivator had a delay drop. your hydraulics are not live, so the clutch needs to be out for them to lift. also they are one way hydraulics, so you can remove one of the lines from the mower so it uses power to lift and gravity to drop. they sell a vented cap to put in the unused port on the cylinder. if you need two way hydraulics, you can use an open center spool valve, run the pressure line to the in side of the valve and then tie the return line into either the fill pipe with a tee at the pmp or tee in to the drain plug. then tie the lift all control back so it supplys pressure all the time, when the clutch is out.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
