Posted by Tom Fleming on August 09, 2009 at 03:29:43 from (67.20.240.67):
I am restoring a 1942 H, and I have a couple of quick questions. I am adding a belly pump, and and working on the arm that mounts on the steering post. it has 2 holes in it, I presume 1 is for the ON/OFF switch, and the other is for the shutter control crank. I am planning to place the ON/OFF switch in the hole closest to the steering post and the shutter control crank on the outer hole. Is this the correct placement?
Other question I have is about the foot starter rod. I know my SM has one, and I wanted to know if that would have been an appropropriate option on the 1942 H. The original starter button location for mine was the box mounted to the steering post using the same bolt as the electric box. However, I would like to use the foot starter. Any feedback here? The gas tank base does have the opening to install the starter button, and is original to the tractor.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
