Randy, I got the 3 shift rails lined up OK but I see something that doesn't look right. Do you have the specs on the large and small swivel shaft pin diameters? I've a hunch someone long ago rebuilt these pins--not to spec, or IH was sloppy. The large 3/4" pin has a 1/2" dia.(plus or minus 1/16") hole through it for the small pin which is WAY off center. Also, the small pin is WAY smaller (3/8" dia.) than the hole in the large pin. Seems awfully sloppy--unless it is designed that way. The shifter lever is close to the specs in your photo. The .75" width is worn just slightly narrower. Sorry for the length of this message but had to get it right! Thanks again. Emails welcome too.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
