Posted by ScottyHOMEy on September 08, 2009 at 07:57:56 from (70.105.237.137):
In Reply to: Re: 1941 Farmall A posted by Joe Joiner on September 08, 2009 at 07:32:54:
Brings up another thought. What kind of lighting do you have? Is it the Bosch no-battery system or the MUCH more common Delco lighting and starting with generator and battery?
If it's the Delco, my best recollection is that it was just a thread of a fuse element inside there, maybe 3 or 5 amps. (A quick spin through teh garage didn't turn up my spares) 20A sounds awful heavy. All that's on it is your lights, so you might want to look around for a short somewhere, chafed wire, bad switch on the rear light if it's a combo . . .
On the really far off chance it's the Bosch system, I've never even laid eyes on one, but I do see that it has two fuses. From the diagrams, one mounted on the switch body, and another separate. No indication in the book of what either of them was for size or load. 8^(
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
