Yep, the VR (if working correct ) has either a Voltage or Current or Combination (voltage and Current) field current control relay THAT SHOULD INDEED limit the gennys output and if its allowing the battery to get to 8 volts (7 TO 7.2 is more typical) ITS NOT DOING ITS JOB PERIOD
Bob M and discussed this and Im of the opinion instead of specifically matching a VR to a particular Genny these days, they are making one size fits all which works fine on some gennys BUT NOT ALL........ One hugeeeeeeee difference (in VR's) is the ohms of the VR's internal field resistor and its different for different gennys but I doubt they really pay that much attention when they make them in Indian or China. If that resistor is wayyyyyyy low I can envision overcharging.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
