Check with a test light as follows: Power at the load side of amp meter (side not connected to starter switch terminal)
power at light switch from Amp meter. Power at wire going to lights (either in the D or B positions, with dimmer in the D position)
Power at the light bulb on each side of tractor. Power at the ground of the bulb, If power at the ground, the ground is bad!! Voltage must be used at the bulb. JimN
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
