Posted by Mark on November 04, 2009 at 13:17:14 from (71.30.209.232):
For those of you that have followed this thread, here are today"s findings:
The distributor is 180 degrees out....so we moved the wires accordingly to put it back in time. The new coil I had bought wasn"t making a lot of spark, so my pal mounted an old, but good, 12 volt coil and the tractor fired right up!
For about 5 minutes and then quit.
Hmmm!
That coil was dead as a mackerel. In fact, when it died today, it acted just as it did when this problem started......run a minute or so and die.
I had a thought.....what if the alternator was charging wide open.....dumping totally unregulated voltage into the system.....could/would that kill a coil?
Obviously, I had to get another coil before the engine would start again and so, I did. I bought a new 12 volt UNballasted coil, added a ballast and fired her up. I checked the VOLTmeter and it was off the scale...buried to the right!
I unhooked the alternator and let the engine run off the battery and then stuck the fluke meter to the alternator....19.4 volts! I never even tried an amp reading.
So.....maybe I am wrong, but I think the alternator fried my first coil, fried the good old one we mounted this morning and would have fried the new one had I left the alternator hooked up.
Oh...have I ever noticed anything with the battery before....No. I think this alternator issue just started.....as in when the tractor first quit a few days ago and I have been busy trying to fix it ever since.
Whatever the reasons, the tractor runs fine now. Hot coil and plug wires put where they needed to be.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
