The coil says 12 volt for use with an external ballast...and that"s what it got. The new internally ballasted version put out a very, very weak spark. This new one...as well as the old/but good one we used this morning would/will make Frankenstein laboratory sparks!
I don"t give a darn if that alternator is toast.....I am afraid it is the culprit and would never trust it again anyway. One wire GM alternators are easy to get.
Scotty, as far as the time being 180 off....well, whomever had the machine before me has evidently had the distributor off and put it back on that way.....I have never touched it. Had I paid any attention before removing the old wires.....that would have been a tip-off. I also don"t know if 19+ volts can kill a coil or not.....but I"m not taking any chances!
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
