Great, I just wanted to confirm what coil you had..... If an alternator is coupled up to the battery/load and the battery voltage is rising to 19 volts thats wayyyyyyy toooooooo highhhhh, its internal voltage regulator must be bad (assuming all is wired correct especially the voltage sense circuit) and the battery can overcharge n boil over acid n get ruined eventaually plus YES the points will burn up faster and the coil run too hot
Sounds like your getting there, she sure runs better if when the points break open the rotor tip is where its supposed to be i.e. lined up with a cap pickup leading to wire and plug located in a cylinder thats nearing TDC on its compression power stroke woooooooo hooooooooooo
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
