Posted by Pete7 on November 24, 2009 at 17:31:41 from (72.65.36.65):
The steering went out on my Farmall 340 today. It has power steering and the steering was Ok the other day (although a little stiff and jerky) but today I can turn the steering wheel and the wheels don't turn at all. The steering shaft turns, but the steering arm doesn't move. If I take the weight off the front end by lowering the loader then the steering wheel will turn the wheels. Does this seem like a steering gearbox problem as oppossed to a power steering problem? The power steering unit for this Farmall tractor is mounted right under the steering wheel and I don't see any other hydraulics by the steering gearbox. Pete
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
