Posted by Armand Tatro on December 16, 2009 at 14:26:40 from (71.201.22.21):
Got to thinking! It's a long shot but---- Is it possible that water could be froze in your steering gear box?????? The gearbox is under the radiator. Take the grill off and you will see a small pipe plug. That is where you add gear oil. I&T manual should tell where drain plug is.I wonder has anyone ever had that gear box freeze?
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
