Back in the mid 1970's I had a B450 and a SMD both at the same time. No engine parts are the same. The pistons are the same bore but the wrist pins are in a different location, from the top of the piston. The blocks are not even close. Nothing about the motors are alike. Even the transmission used different size gears and shafts. The B450 also had a differental lock. About the only thing that would interchance was the front and rear wheels, grill, front boster and steering. I think that was about it. Starters will fit each other but won't work, different ring gear. The B450 did have more power than my SMD.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
