Posted by mike french on January 02, 2010 at 19:52:20 from (71.50.20.171):
In Reply to: IH 884 posted by gac on January 02, 2010 at 19:26:58:
with the loader check the front casting that bolt to the front of the engine and holds the front axle, they have been know to break, I have put couple in over the years, also check the brakes cause they can be a headache, check park brake as to fix it is a good job, other than that pretty decent tractor, good luck
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
