Posted by Rob in Ore on February 02, 2010 at 17:37:10 from (74.4.183.217):
This is an IH240 with a 12v electronic ignition stored in an unheated barn in Western Oregon. I just replaced my cap, rotor and wires. The previous rotor disintegrated and left a bunch of rust in the cap. I have it back together and it is running fine now. There is a hole in the bottom of the cap to let moisture run out. Should I spray a short burst of WD-40 in that hole occasionally to displace the moisture? If so, before or after running?
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
