The 1/2 inch pipe elbows and nipples screw dirrectly into pump casting. Made to remove and install from the outside of tractor. If thats the regular fitting that turns without tighten or loosening, something is broke or stripped. If the pump has oil in it, can' understand why oil is not comming out the bottom of clutch housing when hydralic lever is pulled back. With all ports pluged a good pump will load engine enough to notice when pump is engaged.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
