Posted by El Toro on March 10, 2010 at 05:49:26 from (74.103.74.58):
In Reply to: 350U running lean posted by Formerly PaMIke on March 09, 2010 at 17:37:07:
I think it would be running rich with the main jet opened 5 turns and the plugs would probably be blacken and getting some smoke from the exhaust.
You're probably not getting enough gas to the carburetor causing the engine to run lean. You need to disconnect line at the carb to see if there's a full stream of gas from the tank. If that looks ok pull the tube fitting in the carb and look for a plug screen. If that is clean your main jet is probably plugged and a carb cleaning and rebuild is in order. Hal
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
