Posted by dep on March 23, 2010 at 13:22:51 from (98.191.62.25):
When I went to put the H back together after rebuilding the front end, The steering shaft binds in the cast bearing attached to the tank support. It binds at the bottom of the bearing, so you cant shim the support to elimate it (it would need to go down). The shaft is not bent. All original parts. The center support does not seem bent at all. I put jackstands under the frame and unbolted the front end to see if that was bolted on a bit off, but thats not it either. I didnt notice if it was like that before I took it apart. Any ideas?
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
