Posted by roy prins on May 11, 2010 at 16:23:53 from (96.31.4.122):
In Reply to: engine --td18 posted by roy prins on May 10, 2010 at 16:23:32:
OK it might be a td16 - only going by what someone told me- the no. on the block is UD554M 1343--maybe that will help -- and yes it is a 6 cyl. if you buy it for 1200 dollars you get the whole rear half of the grader and you can scrap every thing else if you would like and come out with a 200 dollar motor--just guessing the wheight of the rest -- it will drive on your trailer and have loading docks to help load-- thanks for looking!!
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
