Posted by Jim Becker on May 24, 2010 at 07:12:42 from (173.57.149.7):
In Reply to: SC mounted planter posted by Dean Olson on May 23, 2010 at 21:19:25:
I haven't run into this situation first hand. But I am likely to with a planter I am going to try either this year or next. So I'm quite interested in how you solve it.
I'd try some sort of insert to take up some space in the can, but a little different method than Gene suggested. I'm assuming you have a Richmond hopper or similar. The part of the outer edge of the seed plate that is exposed inside the hopper should have seed resting on all of it to minimize planting skips. Try an insert like Gene described, but rather than a hole in the center, cut a crescent shape slot around part of the outside. Orient the slot over the exposed part of the plate and dump your seed into the slot. You may find foam rubber easier to work with than styrofoam.
To minimize skips, you may find that you need to plant at a lower speed than you would with an unmodified hopper.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
