Posted by Jimb2 on June 13, 2010 at 17:02:00 from (99.240.236.11):
In Reply to: 3 pt hitch pt CORRECTION posted by john in pennsylvania on June 13, 2010 at 12:05:27:
Hi John, now we have to determine if the problem is caused by: 1)Clogged filters, see caseih.com parts 364 hydraulics page 5-04, item #3 suction screen and item #5 orifice filter? 2)Bad hydraulic pump? 3)3pt control lever not working?
Does tractor have a hydraulic aux outlet at the rear?
Some tests to do: 1)Place 3pt control lever at half way been up & down, then close the shut off knob at right side at front of seat. Next move 3pt control lever up about an inch, hopefully you will hear the hydraulic relief valve make a buzzing noise. Return 3pt lever to mid point and open the shut off valve.
2)Be VERY CAREFUL with this next test as the 3pt arms could raise very rapidly and drop rapidly. Make sure everyone is clear and any implement on the 3pt will not come in contact with tractor. With 3pt control lever at max up position, slowly move the draft control lever upward and see if 3pt will lift up.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
