Posted by JSTPA on June 17, 2010 at 13:13:00 from (24.131.202.230):
In Reply to: alternator update posted by karl f on June 17, 2010 at 12:57:55:
I may get blasted for saying this, but if you take the alternator into a rebuild shop and ask them to put the new style d10ac regulator in it your problem will probably go away.Alot of people don't like 1 wire alts because of the old style regulator that was used.On the test bench most of the ones I build kick in at 1500 - 1700 alternator rpms, with the new style regs, some even a little less. hope this helps, jstpa
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
