I am no authority on implements but I think, for the most part, the standard ag implement cylinder across most brands is 3.5" or 4" by 8". IH used alot of 3.5" x 8". They also designed some implements around the 2.5" x 8". Both these cylinders were also used on C thru 560 fast hitches.
The double clevis cylinders were quick disconnect without the need for tools. Farmers would move them around from implement to implement.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
