Posted by Janicholson on June 29, 2010 at 18:57:34 from (64.61.211.167):
In Reply to: H mag update part IV posted by Zachary Hoyt on June 29, 2010 at 18:39:38:
If you have nice blue coil spark, leave the points and condenser (and coil) alone. It must be passing spark to ground inside the cap and rotor, or the rotor is not aligned, or the tab is broken off, or the button contact in the center of the cap is broken. The new rotor and cap are not a sure thing, Try the old ones to be certain, they are often replaced without cause. Corrosion on their tips/terminals causes no real issues at 10,000volts or more. cracks, moisture, or carbon tracks (visible as a slight discoloration and texture) will provide a path to ground. If the weather is humid, or the tractor has not run for a couple of months. Jim
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
