Re: 1948 Farmall M with TA
Posted by mkirsch on August 11, 2010 at 07:15:21 from (64.80.108.57):
In Reply to: 1948 Farmall M with TA posted by whetmj on August 10, 2010 at 21:03:25:
You say it works like a TA...
How does it work?
The TA is shift-on-the-fly, 2-speed transmission. It gives you 2 speeds in each gear: Direct, and about 20% underdrive.
You pull the lever back and latch it, the tractor shifts down. Release the latch and let the lever ahead, and the shifts up.
In 2nd, if you pull the TA lever you get a speed somewhere between 1st and 2nd, for example.
If you can do that with this little lever, you have something truly unique on your hands. Probably the only one in the world.
Odds are you have a Heisler or M&W "9-speed" gearbox, which simply gives you 4 extra gears between 4th and 5th.
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
