The front Fast Hitch takes 3 valves running 4 cylinders. Front, back, and the sockets rotate.
Rear Fast Hitch
Rear remote for winch which is coming off later.
Left side cylinder which lifts the ice cream freezers.
This new valve bank is set up for power steering. May use that capability to run hydrostatic PS. The drag link on the left side is getting in the way. I have to remove parts of the ice cream freezer drive to lift it.
The PS is going to be a major fabrication project. Don't have the plans worked out yet.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
