Re: hot coil part 3..
Posted by Bob M on June 12, 2000 at 05:32:18 from (192.232.120.194):
In Reply to: hot coil part 3.. posted by gn on June 11, 2000 at 20:12:38:
GN - Here's how to determine coil/breaker point voltage: 1 - Connect one voltmeter lead to each of the two primary terminals on the coil. 2 - Pop the distributor cap, then manually rotate the crankshaft and observe the points - stop when the ignition points are closed. 3 - Now turn on the ignition - the voltmeter will read the voltage at the coil. Assuming you've got a 6 volt coil and ballast resistor, the meter should read somewhere near 6 or 7 volts. If it reads much higher than that, you've got a wrong (too low resistance) ballast resistor installed. Wire gage does not affect coil voltage unless wire gage is grossly undersized - in which case the wiring itself will get hot. Hope this helps...
Home
| Forums
Today's Featured Article -
Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
