Posted by El Toro on August 21, 2010 at 04:49:10 from (74.103.74.58):
In Reply to: F20 Starting troubles posted by Jay Snyder on August 20, 2010 at 19:13:00:
Check the firing order of your plug wires on the cap. Hold your hand over the throat of the carburetor while someone hand cranks the engine to see how much suction you have. You need good manifold vacuum to pull the fuel into the engine. Hal
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
