did you use a 6 volt battery? If you tried to cheat and use a 12 volt you probably burned out the coil, and maybe some other things. Or if you were using 6 volt, might be condenser, check for juice getting to the distributer, before you take it off. sometimes the resistor up under the dash will burn out. could also be a bad connection in the ignition switch, flick it on and off a few times.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
