Posted by dhermesc on September 17, 2010 at 07:58:24 from (24.248.193.103):
In Reply to: Re: ethanol gas posted by tomnj on September 16, 2010 at 17:15:08:
So do you think "straight" gas doesn't have a shelf life?
Hydrocarbons in the gas react with oxygen to produce new compounds that eventually change the chemical composition of the fuel. This leads to gum and varnish deposits in the fuel system.
These deposits and impurities can clog up gas lines and filters, as well the small orifices in a carburetor and the even smaller orifices in a fuel injector.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
