Posted by Janicholson on September 25, 2010 at 15:24:04 from (67.72.98.45):
In Reply to: Farmall 130 Electrical posted by BohemianJon on September 25, 2010 at 05:39:31:
The wiring included below will give you a diagram for an A,B, or C. YOu do need to determine if it is 12 volt, but it is probably 6 positive ground as you indicate. The voltage will not make a difference, the only difference in the diagrams will be the inclusion of a starter relay (if yours has one) but the gen will wire the same. First is from the a terminal on the gen to the voltage reg Arm terminal on regulator (10ga wire), then from the F terminal on the gen to the Fld terminal on the reg (12ga wire), then from the gen bat term to the amp gauge load side (10ga), then to the starter switch (10ga). Vr and gen need perfect metal grounds to work.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
