Posted by chevy_cowboy on November 04, 2010 at 09:33:18 from (75.129.228.150):
I bought a rebuilt carburetor for my 49 H awhile back, with a bit of tuning it ran great, but the bottom of the air/fuel screw always had a drop of gas on it when running, and if you left the gas turned on at the tank the carb would drip pretty badly.
After going back and forth with a few things to try (float level, float valve, etc) the rebuilder agreed to send me another carb to try... I put it on this morning and it leaks even worse, this one is leaking above the air/fuel screw out that little vent hole. At times its streaming gas out of it!
Whats going on with these carbs? I'm not sure what else to try.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
