Posted by Russell Peterson on November 12, 2010 at 18:50:51 from (174.124.43.26):
My M started then died out like it wasn't getting gas. I choked good but then thought I had flooded it so let it sit. The next day it tried to start but didn't. I then took off the gas line to the carburator to see if gas was coming and it was.After putting the line back on I opened the shut off line and gas came pouring out of the line from the carburator.No matter how tight I get it it still leaks. I get the nuts tight and the steel line still seems to be loose inside. I don't understand how just a line going into the carburator can be tightened without leaking. I don't think I lost anything when taking it off.Is there something that goes over the line inside to seal?
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
