Yes soak the carb. But do yourself a favor and clean it before you do. If it is your typical been on the tractor a while carb it will be pretty grubby on the outside and you don't want chaff and grit in your can of cleaner along with your carb. Get and old toothbrush and a spray can of carb cleaner and thoroughly remove any crud you can and then soak it. Be sure to clean your sediment bowl and have a good critical look at your gas tank before you put your newly cleaned and kitted carb back on and start trying to run it. I have taken to using a temporary rubber gas line with a gravity compatible filter for the first few weeks (or months) to make sure any issues I might have are not related to adding dirt into the equation. MAYBE you can avoid some of the mistakes that I made. HTH
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
