farmall 560 problem
Posted by anonymus spelt wrong on December 02, 2010 at 18:30:02 from (174.253.140.39):
When I get it running, it will only run for a couple minuets. Then it will sputter and stall. Then it won't start until its been sitting for about a week. At first, I figured it had used up all the fuel. But it was full. Now I'm thinking there is a problem with the fuel lines. If there is anything else you may think it could be, please let me know. This tractor is not a diesel, it is powered by gasoline.
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
