Re: VR Adjustable?
Posted by Dellbertt on December 04, 2010 at 11:28:49 from (209.172.21.9):
In Reply to: VR Adjustable? posted by Dellbertt on December 04, 2010 at 10:18:09:
Bob,
Thanks for the response. I took my own advice and did a good check in the archives and found two really deep discussions on the workings and adjustment of the VR.
I guess my tractor heard the long discussion we had here in the last week on the Bosch VR. I normally get about 5 years out of a battery on my 300U's but one just failed on me with only 2 1/2 years on it.
Just out of warrantee, go figure.
I have decided to give one more 6v battery a chance. If it doesn't hold up this winter for snowplowing then I will convert the system to 12v. Actually there is a complete stock system for the 350U available. I like the way my stock coil is mounted horizontal on top of the distributor with the two small wires on one end and the large wire on the other.
Thanks,
Dell
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
